hi guys! Can a bad hard idle switch prevent a the 300zx from starting? and does fuel pressure build up when you turn the switch on, I have a gaugue hooked to my fuel line and there is no psi unless i crank the motor, car doesnt start but it cranks to 40psi then it starts dropping to zero.
